can I cancel a wrong purchase of add on?
AdelaWong
I purchased a wrong add on by mistake, how can I cancel it?
2 REPLIES 2
Dunkman
@AdelaWong
You can't cancel the wrong add on yourself via self service account.  You will need to contact customer service agent.  Since prepaid, generally there is no refunds, but many CSA will help you get the correct add-on
Submit a ticket for CSA help.
https://www.publicmobile.ca/en/on/chatbot
Type: purchase wrong add on
Follow the prompts to submit ticket.
dabr
@AdelaWong   You'll need to submit a ticket to customer support and ask them to either swap you to the correct add-on or credit your account for the wrong purchase.
Here's a link to chatbot to submit a ticket:  https://www.publicmobile.ca/en/on/get-help
