Cancel my plan
Marlisa1
I need to cancel the plan and esim I just purchase this morning
1 REPLY 1
slusagm
What was the issue? If setup problem, PM can help without cancelling it
But work with PM directly.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
