Unable to Submit ticket
Elizabeth28
I have entered all the data needed to resolve the major problem experienced at least 20 times to no avail! I have waited hours trying to get someone to fix the issue. I am about ready to switch carriers out of frustration.
1 REPLY 1
slusagm
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
