04-25-2019 08:04 PM - edited 01-05-2022 04:36 AM
04-25-2019 08:29 PM
@Alex888 wrote:
@kenadianDo you have a limit on texts/calls? If you do, check the main page of your account, does it show you how many minutes you used?
A positive balance is irrelevant, you will not be charged for going over your limit you just stop being able to use your phone.
@Alex888 guessing this is a bingo. @kenadian probably assumes (as some have in the past, also incorrectly) that PM offers pay-as-you-go/pay-per-use rates on calling, which they do not. With some pre-paid plans at other carriers, you can load some funds into your acocunt and then make calls at a $x.xx/min rate which deducts from your balance until zero. PM is the oppostie, @kenadian : you have to pre-purchase all services.
04-25-2019 08:20 PM
04-25-2019 08:20 PM
@kenadian Does your self serve portal show that your plan is active? What was your renewal date?
04-25-2019 08:08 PM - edited 04-25-2019 08:12 PM
Firstly...edit out your personal info as this is a public forum with many eyes. (note the three dots on top right of your post. Click and edit your post)
Secondly...which plan did you subscribe to ? Have you exhausted your calling minutes ?
