05-03-2023 12:57 PM - last edited on 05-06-2023 10:26 AM by Dunkman
Hi, I have 1000 international minutes. Can I call Budapest? I tried the Budapest number and it wouldn't go through. I tried this number with and without the zero that's in brackets. Any suggestions? Thx.
+44 (0) 1323 674***
05-03-2023 01:23 PM
Duh again, hadn't done the +/011 thing properly. I was able to get through now, so I suppose I still have the freebies. Thanks again!
05-03-2023 01:13 PM
Duh, you're right, I didn't pick up on your number 🙂
Did you buy the US 1000 minutes or the UK 1000 minutes? Your username has been here for a while. Do you still have the freebies from years past? They included the UK.
Also try 011 ... but the + should work. No zeros.
05-03-2023 01:07 PM
Duh, I just realized that country code IS for the UK. Can you tell me what I'm doing wrong then, since trying this number with and without the zero hasn't worked for me.
+44 (0) 1323 674***
05-03-2023 01:01 PM
thank you!
05-03-2023 01:00 PM
Budapest is not on any list here. Those 1000 minutes are only for either US or UK. You can get those calling cards from like 7-Eleven.
