10-28-2022 03:21 PM
10-28-2022 04:53 PM
HI @richardoliver So, were you able to update the credit card on My Account
If you had some problem updating, wait some time and try again, may an hour
But if you really have problem updating, then you can open ticket with them
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
10-28-2022 03:29 PM
If this is about your new credit card then as from your other thread, you can change it yourself in your account. If that was what you were asking about earlier.
10-28-2022 03:25 PM
Send a private message to CS_Agent
10-28-2022 03:23 PM
Perhaps someone could alert the media. 🙂 Why are you telling us this? You can then proceed to log in to your account and change it there if that's why.
10-28-2022 03:21 PM
HI @richardoliver you made the change on My Account already? If you did, you have done everything
If you like, you can also make a manual payment to make sure it works
10-28-2022 03:19 PM
my credit card has been updated to expiry date 02/26
