08-09-2022
02:11 PM
08-09-2022
06:37 PM
computergeek541
08-09-2022 03:05 PM
It looks like the 2GB permanent bonus is still available. However that may be only for the 3G plans so if you are looking for 4G other then the referral credit discussed above doesn't look like it. Although you will get the 3x reward points for you a full year which is a pretty decent return and would obliterate the new rewards customers who signed up before by a mile and would actually beat what the old rewards ppl are getting with the $2 autopay/month etc.
08-09-2022 02:33 PM
iPhoneinCanada has just reported there's an 12 months 2GB bonus on plans $25 and above.
08-09-2022 02:13 PM
Hi @xujun1818 not at the moment.
But they might have flash sale once in awhile
For now, get a friend referral code to save $10 one time. That is the only thing at the moment
08-09-2022 02:12 PM - edited 08-09-2022 02:16 PM
just for new customer
enter your email and the same email you will be activated in here: https://publicmobile.ca/en
Edit: also use your friend or family member for refer a friend code to you will getting one time $10.
