air time roll over
RODNEY2008
Does any one know if plans rool over to next month if less data used or does it start over and same for air times thanks
geopublic
@RODNEY2008  Plan data and minutes do not roll over they get reset every 30 days. If you need backup you can purchase add-ons. If you purchase an add-on the data or minutes stay on your account until they are all used up.
Jackhyf63
Unused data in your plan will expire after renewal.  In Canada Add-Ons, any unused data or minutes will roll over to your next cycle.
gblackma
No @RODNEY2008 plans reset every 30 day cycle. Addons other than the 10 day roaming ones roll over until used up.  Stay safe.
Triguy
Plan data expires at the end of a 30 day period. Only data add-on rolls over to the next month until it is used up.
Staliger
@RODNEY2008 No, everything resets to 0. Except your Addons or promo items.
Jb456
Plans do not rollover.
If you have an add-on like $5 for 500 Canada wide minutes or 1 gig data add-on they roll over until all used up.
USA add-ons are 10 days from purchase and then they stop.
