08-27-2020 11:11 AM - edited 01-05-2022 12:57 PM
Hi
I was on old LET plan - now I switch to $30 3G plan. My phone network is still set to LTE/WCDMA/GSM (auto connect)
how do I know I m getting 3g speed ?
I also have other options on network - do I need to switch to any of this ?
WCDMA Only
GSM only
08-27-2020 04:33 PM
@mpcontact wrote:Hi
WCDMA Only
GSM only
You could always experient to see what works best for you. With that said, don't try the GSM Only setting because it won't work. Also, you're LTE speeds will remain at full speed for the first 48 hours.
08-27-2020 11:16 AM
@mpcontact that is the correct network setting you do not have to make any changes.
08-27-2020 11:15 AM
@mpcontact Leave it as it is. You would be connected to LTE, but the speed is up to 3mb.
08-27-2020 11:13 AM
Keep your settings on auto.
It's LTE throttled to 3g speed.
