06-15-2026 02:05 AM
06-15-2026 09:56 AM
@rainsingh wrote:when i call 611 it hangs up immediately on me
it's *611 instead of 611
also, why not use the browser or app to add minutes? easier that way
06-15-2026 07:27 AM
try dialing 1-855-478-2542 instead.
06-15-2026 04:43 AM - edited 06-15-2026 04:45 AM
What is the make and model of your phone?
Try resetting the Network settings on your phone to see if that helps.
You will need VoLTE to make or receive calls due to the 3G shutdown.
Your phone will also need to be on PM whitelist as well to work.
Here is more information on VoLTE so enter the IMEI of your phone to see if it is VoLTE compatible:
https://www.publicmobile.ca/en/get-help/articles/volte
If your the latest 2026 phone and the IMEI indicates that it is not compatible is because the whitelist has not been updated so contact a CS_Agent.
If it is a older phone that is not VoLTE compatible then you need to look for a newer model phone.
