activation
JHAYmUMALI
my phone went for activation process now i cant use my lineplease help as soon as possible
11 REPLIES 11
CSA_PM
Customer Support Agent
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
JHAYmUMALI
that’s what exactly says
hi @JHAYmUMALI
what you see when you say "subscription was gone"?
if you see the message asking to to pick a plan or resume subscription, you need to message PM as suggested above
@JHAYmUMALI
The website is finicky.  YOu can try to clear cache first, incognito mode or a different web browser. Or try the PM app itself.
JHAYmUMALI
I can login, but the subscription was gone
@JHAYmUMALI
when you last have the service? if you just lose the service due to payment issue, and unable to login My Account, ask PM to help.
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
JHAYmUMALI
it’s only my anniversary date like renewal date for my plan
JHAYmUMALI
no I didn’t
JHAYmUMALI
and the account associated with the number was gone I mean it says there is no account associated with this number
JHAYmUMALI
no, I didn’t. It’s just my monthly renewal.
Dunkman
@JHAYmUMALI
More details would be helpful.
Did you activate a new phone number?  Port over a number from anotehr mobile company?  eSIM versus physical SIM card? Any service at all?
