activation
colin30
How long until you can text with your new public mobile sim card
hi @colin30
how long you replied yes to old carrier? After that, it could be another 2 hours for the port to complete. Reboot the phone once in awhile and chexk inbound calls again
@colin30  There’s. A number for live support that can re trigger the port request for you will send private message
colin30
Yes, I did all of these, but no luck. I can call out but cannot text and no one can call in.
hi @colin30 you posted  number? after you replied YES to your old carrier to approve the porting, you can put in your PM sim card
@colin30  Reboot the phone . You should be able to right away
