2 hours ago - last edited 2 hours ago by computergeek541
Afternoon
I need to change the phone number for my activation code
and also add my email it it
so I can get the code to activate my phone
2 hours ago
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
so, you have an existing PM account and just cannot login EverSafe? Since you cannot login, you won't be able to submit Chatbot ticket, you can ask PM to help by sending them a message:
2 hours ago
I need to reset my eversafe with a new number to get my code to activate my phone
2 hours ago
are you activating new account with PM?
or you have a new phone and try to attach it to an existing PM account?
