account
02-16-2024 02:42 PM
02-16-2024 04:24 PM
I'm not sure if you are having the same issue I was having, because your post isn't clear about your exact problem, but if you are having trouble getting your address to be accepted into the Public Mobile profile, then it might be similar to my previous issue. It wouldn't accept my new address no matter what I tried.
In the end I had to send a private message to the customer support agent CS_Agent in the community here and after a few back and forth messages, it was finally changed. 😊
02-16-2024 02:48 PM
Please note were are customers like you. I understand that you want to finish, but patience is always required.
What are you trying to do? More information please.
Did you download the Public Mobile app? If so, try to Uninstall and try again.
02-16-2024 02:45 PM
HI @Tang64
we might need more information as to what you are doing
Are you trying to activate? if you are trying to subscribe new account, please download PM app and try from the app instead
