07-27-2022 04:33 PM
so i have been able to log in in over a week due to internet issues and website issues and i believe my acct was de activated any way to check?
My Account
08-06-2022 03:54 PM
@sum1 wrote:so does this mean that if i recieve no cell network the sim is dead?>
Maybe, but first call 1-855-4PUBLIC, enter your phone number and see if they can locate your account.
If they can still find your account, then YES, you can reactivate it. Just login to Self serve My Account, click "Reactivate My Account" button and then make payment.
If they cannot locate your account, that would mean the account was suspended over 90 days and your account was closed and your have lost your old number
07-27-2022 07:30 PM
07-27-2022 07:27 PM
@sum1 wrote:so i have been able to log in in over a week due to internet issues and website issues and i believe my acct was de activated any way to check?
@sum1 - if you ported your public mobile phone number over to another provider OR, your public mobile account has been in suspended status for over 90 days the account, and access to self serve is gone.
Do you have the PM sim card? If so, insert it into a phone and dial 611. Or, dial # 1-855-478-2542 from another line, and you can find out if the number is still Active or in Suspended status...or not available/gone.
07-27-2022 05:35 PM
@sum1 try to message them and explain the situation. In some case, they might agree to give you back the same number if you activate a new account with the new sim card.
Message them here:
07-27-2022 05:31 PM
if you passed 90 day you losing everything in account phone number and sim card but give a tried to contact support them i post to you a link contact them maybe them can getting back your number but you need start new plan and new SIM card.
07-27-2022 05:30 PM
@sum1 No, the old sim was used and the account was closed, the sim cannot be reused on a new activation. You need to get a new sim card from store
07-27-2022 05:27 PM
so as a secondary question is it possible to re activate the current sim i have, with a new number if need be
07-27-2022 05:26 PM
ya i think the 90 days has passed couldnt log to put money on acct in the last week and sunday or monday was date i believe
07-27-2022 05:20 PM
how long you didn't make payment to your account if over 90 days is will lose everything in here.
07-27-2022 05:19 PM
if it has any bearing the sim is still showing number in phone settings
07-27-2022 05:17 PM
great advice. have done. wondering at this point if acct is recoverable if it was de activated
07-27-2022 05:11 PM
07-27-2022 05:08 PM
cant no email, numbers are recieving any verification codes
07-27-2022 05:05 PM
@sum1 In that case, try resetting your password: https://myaccount.publicmobile.ca/en/forgot-password
07-27-2022 05:04 PM
changing passwords by email<registered acct> or >sms<do not work
07-27-2022 05:01 PM
use browser from computer, and clear cache and cookies and use one page inPrivate mode,
you will get verification code by email or SMS
and when you press the 6 digit number and not press anything
just wait a 3 second automatically be login.
07-27-2022 04:54 PM
between my internet going down and the website over the past two weeks . but now just says wrong email or password though i know they are both infact correct ,or once were
07-27-2022 04:38 PM
@sum1 Do you get any error message? Are you correctly entering your email and password? If yes, it should take you to the verification page and you can use E-Mail verification method. Try using incognito/private browsing mode.
07-27-2022 04:34 PM
replyin to self... should read have not been able to log in
