01-02-2018 09:45 PM - edited 01-04-2022 03:14 PM
01-02-2018 09:47 PM
Do you mean you can't log into your self serve portal?
If so, you need to contact a moderator via private message. The forgot/reset password feature is not working.
Information regarding the moderator team can be found by following this link.
Click here to send them a private message. Be sure to privide the necessary information to identify yourself.
01-02-2018 09:46 PM
@harman4 You will need to send a private message to the Moderator_Team with your account info. They will get back to you tomorrow morning.
