my account
01-08-2025 05:19 PM
01-08-2025 05:24 PM
Hey there, this is a public forum and we would need more information to help.
Have you forgot your login? can you reset your password? If you have tried that and are getting some error message that wont allow you to access your account, you may need to contact PM Customer support, which you can do so using this link:
01-08-2025 05:23 PM
@Yoyo4 are you getting an error message, if so what is it?
If you are not getting the 6 digit verification code you should be able to click on "Didn't get code" and then select to resend as email
