10-24-2017 05:14 PM - edited 01-04-2022 02:48 PM
As it says in the title. I have internet, messaging and provincial calling on my account but can only call out. Call in, sms and mobile internet do not work. I ported my phone number from virgin mobile. My phone is unlocked. Lemme know what ya think
10-24-2017 05:26 PM
Done and done, thanks a ton
10-24-2017 05:24 PM
Send a private message to @CS_Agent right now.
Provide the phone number and all the info needed to port from Virgin.
Also provide your public mobile sim card number. Just want to provide all the info so they can go staright to fixing this.
10-24-2017 05:23 PM
Ah this happened two days ago so I'll contact a moderator. I did the APN stuff and no luck
10-24-2017 05:20 PM
Hey @Boromokott,
It takes anywhere from few minutes upto couple of hours for the number to port. In the meantime, your Virgin sim will continue to work. Virgin account will be closed automatically when the number ports to PM.
For data, you will need to manually enter the APN settings: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Setting-Up-Data-APN-On-Your-Ph...
If it has been more than 2 hours, you will need help from @CS_Agent to resubmit your port request as it has failed for some reason.
10-24-2017 05:19 PM
How long ago did you port over?
