2 weeks ago
have subscribed a highly advertised public plan $29 for 20gb monthly. I have received the sim but not inserted due to following
2 weeks ago
@softech wrote:@raiman there are 2 options for this plan $39 for 30ndays for $24/30 days with a 90 days subscription (you need to pay $75 upfront for the 90 days). You picked the wrong one. But easy fix for PM, please message PM support to sort it out
@raiman to be clear the two options for this plan are . $29 20GB 30 days or $25/30 days with a 90 day subscription ( but you need to pay $75 upfront and get 60GB to use over 90 days ) but as mentioned above support can sort it out for you .
2 weeks ago - last edited 2 weeks ago
@raiman there are 2 options for this plan $29 for 30 days for $24/30 days with a 90 days subscription (you need to pay $75 upfront for the 90 days). You picked the wrong one. But easy fix for PM, please message PM support to sort it out
2 weeks ago
@raiman if you think there is an error with your plan, use the chatbot to submit a ticket for public mobile to correct. In your app use the support section or the orange bubble. Type customer service agent.
Or use this link.
2 weeks ago
@raiman Truth be told that’s better deal then 20GB for $29 you save $12 over the 90 days . But you can ask support if they can fix it for you . if you really rather pay $4 more for each 30 days
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
send a private message To CS_Agents
2 weeks ago
