03-18-2024
01:49 PM
03-18-2024
03:25 PM
computergeek541
Hi there,
I bought a sim card and a new plan on March 4, 2024 and I havent received my sim card yet. It still says "processing" but it says it should have been delivered March 13th. Can someone provide me with an update?
Thanks,
03-18-2024 02:03 PM
SIM. Card can take up to 3 weeks to arrive .if you need one sooner try calling local Telus Koodo stores for in person pick up or order from Amazon .otherwise reach out to support for a status up date for when it shipped and when you can expect it . Or if you can get a credit for buying a new SIM card .message support directly while your already here and logged in the community you can send a private message To CS_Agents
03-18-2024 01:52 PM - edited 03-18-2024 01:53 PM
@AamnaC - A SIM card can take up to 4 weeks to arrive.
If you need it ASAP, go to your local TELUS / Koodo Store (Or even any Mobile Klinik) for a SIM card. Also Amazon has them for $5 at discount.
If you want an update, contact CS_Agent:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
