11-30-2024
03:30 PM
11-30-2024
03:32 PM
computergeek541
Hi,
@CS_Agent My wife's account looks like has wrong email being used so she can't seem to get the OTP email with the code how can I reset the accou
11-30-2024 04:42 PM
11-30-2024 03:46 PM
I assume that you unable to receive 2FA text to access your account? That is usually the first option to access self service account. If that fails, then you can get 2FA email instead.
Then you will likely need to get CSA help
Send a private message to CSA through the following link :
11-30-2024 03:44 PM - edited 11-30-2024 03:45 PM
hi @SuperV CS agents do not monitor posts here in the community. Your wife has to contact agent. Please submit by direct message:
