5 hours ago
The email address associated with my public mobile account is incorrect. How do I fix this. My account is still active but I can’t login
5 hours ago
You would have to submit a ticket to a Public Mobile CS agent to change the email on file.
Use this direct link
To check your message click your avatar then click messages or click the envelope icon.
5 hours ago
@Uschi , do you know the email address associated with your account even if "wrong"? You can login and then manually change it yourself from the profile tab, eversafe ID.
