05-17-2022 12:11 PM
I am getting wrong data usage notification (every month). This month till now I used only 401.023MB of my 2560MB. I was notified that I used 75% when it was only 15%. Last month also I received similar notification which was wrong and after two days it showed I completely used my data.
Can someone please help me to find a solution for this? A screenshot of data usage is attached.
Thank you
Praveen
05-17-2022 08:57 PM
@praveenharan wrote:@computergeek541 Thank you for your message. What is link for? I can not access!
That link isn't supposed to be accessible. It's only a placeholder to indicate that I've removd a message that was merely repeating a previous message.
05-17-2022 08:20 PM
05-17-2022 01:55 PM
unnecessary repetition
05-17-2022 12:24 PM
You might be interested in changing the plan to the newer version of that plan. It's now 2.5+.5. You have the old 2+.5.
05-17-2022 12:19 PM
HI @praveenharan these text are sometimes wrong, usually we just ignore. But if you want to look further, open ticket with PM:
open a ticket with PM Support. Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
05-17-2022 12:18 PM
Unfortunately many complain about this notifications even they have a lot of remaining data.
You can talk to agent why is this happening but most likely have to accept this erroneous SMS. Check your account for remaining data as that is the most accurate counter.
05-17-2022 12:15 PM
@hTideGnow Thank you for your reply.
None of the bonus data is remaining. It was finished long time back.
05-17-2022 12:13 PM
HI @praveenharan Do you have other Bonus Data from Christmas bonus? It could be 75% used including those bonus data, not just 75% of your monthly allocation.
