Wrong Phone Number
eliteearners
I am hoping this isn't a unique situation and someone has had the same or relevant experience.
A few days ago, I signed up to Public and requested my phone be ported from Rogers. Due to some account issues, or whats more them being them, the port failed. Someone from Telus called me and assigned a new number to the account. Which is actually showing inside the account here in self serve.
Here's the issue ...
#1 - restarted my iPhone and the number which was supposed to be ported is still there
#2 - calling out works ... but with that number
#3 - no one can call or text me on either number
#4 - all usage inside the self serve is on the number that was suppose to be ported.
Not new to cell phones or iPhone - did a full system reset and network reset. Nothing is working to get the failed port out of the phone and the new number in.
Unfortunately in this case, only modeator from public mobile can fix it.
They are open tomorrow.
eliteearners
Already sent a few message, awaiting their return. My personal belief is that they didn't fix the failed port inside the Public system. My "new" number assigned via Public is inside the self serve, but again doesn't work. And no the sim with rogers is dead. The account is dead too, in the middle of a claim against them right now. None of which would make issues with the account at public or the failed port. It failed, because they will not open to allow port.
Lieux
Sorry for you @eliteearners
you will need help from the moderator. https://productioncommunity.publicmobile.ca/t5/notes/composepage
And give them an explanation of what happened. You need to wait few hours or up to 2 days... be patient they will help you..
MoreYummy
It is port failure.  Only way to fix it is contacting @CS_Agent
Send them your account info, go from there.
Dunkman
@eliteearners
It does look like the porting was not done properly.  You will need to contact moderator via private messaging to sort things out.
Does your Roger's SIM card still work?
Send a private message to moderator through the following link :
