09-07-2022 11:48 AM
Porting not finalized due to the wrong IMEI prowided.
09-07-2022 02:19 PM
Unfortunately 7-11 is my case. The good news is the Porting Team is working on it.
Regards,
Jack.
09-07-2022 12:14 PM
The easiest way to IMEI check on any phone is to use the *#06# sequence.
09-07-2022 11:57 AM
HI @Jack107
I have sent you a number to call to talk to Porting team to update the information. Check your Community inbox. They should be able to re-request the porting after
09-07-2022 11:54 AM
Call the number in this link. Put your old sim back in a phone and confirm the text.
Maybe this could be appended with your other moderator question.
09-07-2022 11:51 AM
@Jack107 wrote:Porting not finalized due to the wrong IMEI prowided.
Unless you're coming from Petro Canada or 7-11, IMEI shouldn't usually be used. The account number would be better. To make the correction, please open a ticket and ask for the help of a customer support agent. Start here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
