With Canada/US plans, how long can I roam?
h3adgskt
My previous provider had restrictions in the fine print, but I haven’t found any with PM yet. I’m just wondering if anyone knows the maximum days I can roam in the US with my $34 Canada/US plan before being cut off?
For sure @DennyCrane,  thanks.
Just wanted to point out the data limitation as a reminder. 👍
h3adgskt
This is correct. But I appreciate all the insight everyone has given!
@HALIMACS I think the question was more about whether you can only be in the US for a certain percentage of the time. Some other carriers have such restriction, as they don't want you down there 100% of the time. I've never seen any such restriction at PM, beyond just the standard reasonable use clauses.
HALIMACS
Not entirely 'unlimited', @h3adgskt
While you can call & text unlimited, your data will only last as long as your data allotment allows, after which it'll just stop until the next cycle renewal or you purchase additional data.
h3adgskt
Amazing! Thanks for the update!
@h3adgskt  You can roam unlimited . It’s a true snow bird plan and can be used in either country to call either country talk text and data . So long as you keep the plan .
