Windows 10 APN settings? fixed. Automatic settings
Simon4s
PM's Setup your phone (APN) shows the proper setup for Windows 8 but but the APN setup interface is different on my windows 10.
Is there an APN setup guide for windows 10 phones?
EDIT: ShawnC is right. Should be fully ported now, default/automatic settings are working now
arkw
I find that if you go to your phone settings (though not with a W10 phone), you can scan and set network providers, which will force update your APN and register your SIM with the providers network.
I did this and my APN automatically changed to PM's settings.
ShawnC13
I am running W10 and am on the fast ring Preivew,  I did not have to change any APN settings.  I could be that you are completely ported yet
hummuschips
Is this the same one you were looking at?
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-APN-on-my-Windows-...
If you scroll down, a post by pylon explains which settings correspond with what for Win 10 vs 8.
