Will this phone work with PM?
deraly
Hello,
I am looking to buy a Chinese smartphone online, this phone uses the following network, can anyone tell me if this phone is compatible with PM? Thank you for your help
  • 2G GSM: 850/900/1800/1900 MHz
  • 3G TD-SCDMA: B34/B39
  • 3G CDMA: BC0
  • 3G WCDMA: B1/B5/B8
  • 4G TDD-LTE: B34/B38/B39/B40/B41
  • 4G FDD-LTE: B1/B3/B4/B5/B8
  • 4G+ TDD-LTE: B38C/B39C/B40C/B41C
  • 4G+ FDD-LTE: B1C/B3C/B1A+B3A
2 REPLIES 2
cellphoneuser1
@deraly wrote:
Hello,
  • 3G CDMA: BC0
Avoid it. When they show specs that sometimes show more than one version at a time. Make sure you get the right version of the phone you choose.
GinYVR
@deralyIt misses 3G B2, it would work but not well. I would give it a miss.
