Will i be using my roaming plan or my regular plan
stefdav55
I am visiting in the states from Canada and I am wondering, if I want to call home, (back to Canada), will that be on my regular PM plan or my Roaming plan?
Thanks!
stefdav55
Thank you everyone!
@stefdav55 wrote:
I have the US roaming with talk, text and 250mbs data
@stefdav55  - are those addons you mentioned... these two ?
Your Public Mobile plan details are listed here:
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/
If you purchased those above 2 addons than I presume your plan is one for use only in Canada; therefore, those addons you purchased will be used when you call from the USA to home (back in in Canada).
HALIMACS
@stefdav55
Unless you have USA roaming included with your plan, you will need a roaming add on.
If you want to save on that, use a VoIP calling app with Wi-Fi.
stefdav55
@stefdav55 - for all inmarket Public Mobile plans you will need to have Roaming Addons purchased to use Public Mobile services in the USA on top of having an active Plan.
The exception, is, you can still receive texts when in the USA without any Roaming addons.
There was a 'snowbird' plan offered for a period of time, a few years ago, that did include Canada and USA services within the plan. Which plan are you on?
BEER
Roaming plan.
