Will an older Samsung Galaxy Core phone work with PM?
KenD
It's frequencies are UMTS / HSPA 850, 900 and 2100 MHz. I believe this means that there is only 1 frequency that matches Public Mobile...the 3G 850 MHz.
9 REPLIES 9
KenD
Sorry for the delay in replying. Thank you for the information! Problem solved!
@KenD wrote:
This phone is not the Core LTE. It's just a Galaxy Core. It's not a smart phone.
The SM-G386W is the the Samsung Galaxy Core LTE. It is an Android smart phone, although an old one. When carriers advertise a model name, they sometimes leave out parts of the name on the packaging, especially on the website or if they repackage it into a specialized prepaid carrier packaging. In this case, anything that has a model number of G386W is exactly the same phone, whether it says Galaxy Core or Galaxy Core LTE on the packaging.
You gave the model number earlier???
KenD
@KenD wrote:
Hi. The model is SM-G386W
The Galaxy Core LTE G386W is the same model that both Koodo Mobile and Telus Mobility have sold. Interestingly enough, I happened to come a across one that was sold by Koodo that required a network unlock code after inserting a Telus SIM card (but obviously not for a Koodo SIM card).
@KenD  there's a few threads if you use search bar at the top with G386W that others have this phone working on PM.
The phone should work fine all around.
KenD
Jb456
@KenD
What core do you have??
Or give us the exact model number so we can confirm.
