06-14-2022 11:09 AM
The $50 plan has 10GB Data. My $50 plan only has 8GB Data. Will it be auto updated to 10GB Data?
06-14-2022 12:55 PM
Clear your browser and reboot your device. Use chrome or firefox. Log in. Go to the plans page. Choose the new $50 plan and schedule it to change on next renewal. Take a screenshot. Log out.
06-14-2022 11:13 AM
You'll likely have to "upgrade" to the newer $50 plan.
06-14-2022 11:12 AM
@PreachJohn1 hi go into your self serve under plans click your plan to change at next renewal
06-14-2022 11:12 AM
Never say never but no, you would need to change to the improved plan. It's the proper way of grandfathering plans. Unlike the butchery they did for the old $10 plan.
