Why won't it update my new bank card?
Chantalle
Chantalle
I'll try this thank you
Chalupa_Batman
Hi @Chantalle
Sometimes in your browser you may need to go to the settings and clear the cache as this website tends to cause it problems once in a while. Try clearing the cache history and cookies. Then shut down the browser and re open it and try again.
HI @Chantalle
you got an error message?
Sometimes changing card could be tricky.  Just want an hour, then use the browser to change, and use Incognito/Private/Secret mode to make the change, it should work then
