03-02-2019 03:18 PM - edited 01-05-2022 06:46 AM
hello, i am with public mobile and on my phone it used to say public mobile, but now it shows telus, im not sure what to do.
03-02-2019 04:08 PM
Hypothetically, even if the phone was still showing "Telus" in the network banner/notification area, this doesn't have anything to do wtih the Public Mobiile service. \
The identification/network name shown there is based on what is programmed in the software of the phone. While it is true that the sim card does have a pre-programmed name that overrides the names of the networks names that are in the device's software, it is still up to the device manufactuer's software to set itself to use that information from the sim.
As such, this isn't something that moderators would be able to do anything about. Personally, I prefer the real network names such as Bell, Rogers, Telus inteaad of stuff like Public Mobile, Away, or EXT. This preference is also likely why many custom ROMs will show "Telus" instead of Public Mobile even with a Public sim card insterted in the phone.
03-02-2019 03:27 PM
@_parth23 wrote:yes, everything works fine
As long as your services are working I personally would just leave it alone. It's probably a phone update who displays information on the SIM differently (you are connected to the Telus network after all.)
03-02-2019 03:27 PM
Ouf!!! Great!!! @_parth23
03-02-2019 03:26 PM
Turns out everything is fine, reset my phone and now it works fine, public mobile came back.
03-02-2019 03:24 PM
Ok very strange then...just to be sure you can write a message to the moderator...
waiting time is few hours to 2 days....and I don't know what to think about that...but hopefully your phone is ok....![]()
03-02-2019 03:21 PM
03-02-2019 03:20 PM
Hello @_parth23
Can you call and text?
