Why have I not received Christmas gift promotion. I replied to the text
norm144
norm144
Problem solved. Thanks
CountyDownIeUk
Did you reply "YES" or "YES2" ?
YES replies will take longer.
Upon your reply did you get an immediate response like:
Meow
Contact agent to manually add your bonus. Have screenshot of your replying YES2 to SMS.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@norm144
Get in touch with a CS_Agent and they will add it in manually. Click on SIMon Chatbot below or private message them above.
walker1
@norm144
Try logging into your account using a browser in incognito or private mode instead. Try looking at your account again, then do a refresh.
You can still get the gifts applied manually to your account by a Customer Support Agent if you ask.
Just use the Chat Bot Simon to get a service ticket started first.
