09-28-2022
05:27 PM
09-28-2022
06:08 PM
computergeek541
We just switched to PM few days ago and my husband isn’t receiving calls. When I call his phone, it says long distance charges may apply and then goes to VM? Why?
09-28-2022 07:48 PM
Yes we did
09-28-2022 05:57 PM
Will give that a try
09-28-2022 05:36 PM
If this was a ported number, port could be stuck @Flyawayrobin . May need CSA help to reinitiate the port:
Contact a Customer Support Agent (publicmobile.ca)
If this was not a port, have the phone restarted, and perform a reset of the device's network settings.
Oh, and also check that the DND (do not disturb setting has accidently been turned on).
Try adding a '1' in front when you call him, that long distance message will likely go away.
09-28-2022 05:36 PM
#1 - that recording is that you didn't include a 1 in front of the number.
#2 - which leads to the likelihood of a porting problem that you ended up going to voicemail. I'll bet that was the old voicemail if you were to leave a message.
Did you leave the old sim in the phone to reply to a confirmation text if you did in fact transfer an old number?
09-28-2022 05:35 PM
select the network manually to 3G and reboot phone.
ignore those message and add 1 in front of are code,
09-28-2022 05:32 PM
Did you do porting of your number at the same time when you opened account?
09-28-2022 05:29 PM
@Flyawayrobin wrote:We just switched to PM few days ago and my husband isn’t receiving calls. When I call his phone, it says long distance charges may apply and then goes to VM? Why?
This could be an issue with the network's ability to switch from the LTE to the HSPA network needed for phone calls. This isn't ideal no a permanent solution, but try setting your phone to 3g-only network mode temporarily to see if that helps.
