Why cant i send messages but i have unlimited texts
Ashadrle2006
My plan says i have unlimited texts and calls but it wont work even with my data on.
corrio
I had this happen to me recently and I ended up turning my phone off and on (or may have just turned on airplane mode and off). But it worked. Hopefully it's a quick fix for you!
@Ashadrle2006
Can we get more detail so we can help further?
Did you recently ported your old number over to PM?
If so, you need to contact a CS_Agent to restart the porting process for you.
If not, check to see if there is an outage in your area by checking the map:
https://istheservicedowncanada.com/status/telus/map
HI @Ashadrle2006
if you just joined PM, maybe a Reset all networks will help.  Try it
will13am
@Ashadrle2006 , are you using an iPhone and have iMessages on?
Meow
Do you use Native SMS app or some 3rd party app?
With native app if you have service SMS should go through. Only MMS require Data on for native texting app.
