12-24-2021 03:06 PM - edited 01-04-2022 04:45 AM
My service has been out for 2-hours, and so has my daughters! My phones are just fine, but your service is obviously not!
12-24-2021 03:58 PM
12-24-2021 03:44 PM
@Raelee_1 Great! Merry Christmas and Happy New year 🥳🎅☃️🎄
12-24-2021 03:42 PM
ThankYou!!! Set it to WCDMA/GSM and its now working!!!
12-24-2021 03:25 PM
@BeachNBeer wrote:
Last 4 digits of sim card on your account match the digits when you take it out of phone?
It could be network issue since both phones are not connecting.
Hi @Raelee_1 you have a 3rd phone you can try to put the SIM into it?
12-24-2021 03:21 PM
12-24-2021 03:17 PM
Yes! Both are Public Mobile accounts, in good standing!
12-24-2021 03:15 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck...
12-24-2021 03:14 PM
HI @Raelee_1 not from the Telus outage page. Did you try reboot your phone?
12-24-2021 03:13 PM
To get things out of the way. Log into your accounts. Is status active or suspended? While in your account click the change sim card option. It will show last 4 digits of your sim card. Take sim out of phone. Do they match? Repeat with daughters phone.
12-24-2021 03:12 PM
@Raelee_1 wrote:My service has been out for 2-hours, and so has my daughters! My phones are just fine, but your service is obviously not!
@Raelee_1 - what does it say when you call 611 on the devices?
When are your accounts due to renew? Was it today?
If you have Autopay enabled, perhaps it was a failed Autopay. If this is the case you will need to top up both accounts to resume/reactivate services.
Check your Self Serve accounts.
12-24-2021 03:11 PM
Hi...It says 'no network' when I try to call or text...Tillsonburg,On area
12-24-2021 03:09 PM
@Raelee_1 - well, it does sound like some kind of network disruption if you have 2 phones with no service. Are the both Public Mobile accounts?
check for any outages in your area:
https://downdetector.ca/status/publicmobile/
Did you both restart your phones recently? If not, do that.
Removing and reinserting your SIM card can help sometimes, as well as toggling into airplane mode, than back again.
12-24-2021 03:09 PM - edited 12-24-2021 03:09 PM
HI @Raelee_1 , you see the phones connected to PM or No Network?
which area is that? did you check Telus Status/Outage page?
12-24-2021 03:07 PM - edited 12-24-2021 03:09 PM
@Raelee_1 Have you logged into your accounts to see if the status is active or suspended? What area are you in?
