Why are add on's so expensive
02-07-2020 11:32 PM - edited 01-05-2022 09:24 AM
02-08-2020 04:07 PM
I believe you mean the data plans. The phone plan add on 500 minutes Canada Wide long distance for $5 is an excellent deal.
The data plans are pricier with $30 for 1GB plan and $10 for 200MB add on. If you need more data upgrading your plan to the next best thing is worth it.
Upgrading the $40 plan to the $50 plan gets you an extra 3.5gb.
02-08-2020 10:51 AM
Talk add-ons are very affordable.
1c/min Canada, 4c/min long distance countries is very competitive.
So you are probably referring to data packages.
The fact is that is 1g was $5 almost nobody would get any other plan but 15, some who are big talkers would go for 25.
$10/1g would make 35 plan absolutely obsolete and many who are on 40 just because it's only $5 more than 35 but you get so much more would also downgrade to 25.
I believe $10 would still be great option for both users and the house, as everybody would be much less cautious about their usage and would be much more likely to buy that add-on, so the house would still get the same.
But yes 30 is too much in my opinion
02-08-2020 09:38 AM
The data add on is expensive but it rolls over to the next month - your best bet would likely be to change to a higher data plan!
02-08-2020 03:31 AM
@yanzhiqiang wrote:We got free add ons during Christmas.
Because that’s a standard marketing tactic, as nice as it was.
02-08-2020 03:06 AM
02-08-2020 01:27 AM
In short, because it’s telus.
02-08-2020 01:04 AM
@ivanwill123 Public Mobile prices the data add-on high because they would prefer that you move to a higher priced plan instead of using the add-on.
02-08-2020 12:47 AM
@popping wrote:It depends on which add-on.
The $5 500 Canada wide minutes is very cheap. It is only 1 cent per minute. It is like getting a calling card without dialing the long string of numbers.
If you want more data, you can change to a plan which meets your monthly usage patterns.
I agree, addons are quite expensive for PM. Hope, they will decrease price eventually.
02-08-2020 12:35 AM
Add-on data is priced higher due to the non-expiring attribute. I do agree it is still expensive which means I won't ever buy it.
02-07-2020 11:35 PM - edited 02-07-2020 11:38 PM
