While in US can I use my husbands SIM card on my compatible volte phone
michellebisson
Can we switch back and forth my husband's sim (he paid for the US plan to find his phone is not volte compatible) card onto my phone.
I tried & the phone worked but not the data.
2 REPLIES 2
Dunkman
@michellebisson
As mentioned, your husband SIM card should work in your phone.  If data not working, might want to reboot your phone or do a network reset of phone (ie. this will erase any saved Wifi passwords).  Or you could try to manually select another US partner carrier (AT&T, T mobile or Verizon).
Here is some more troubleshooting advice:
https://www.publicmobile.ca/en/get-help/articles/us-roaming-troubleshooting
@michellebisson
It should work but your phone will be under his number but what is the make and model of your phone? It should be on the whitelist of phones that will work in the USA.
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
