07-23-2019 05:54 PM - edited 01-05-2022 06:03 AM
07-23-2019 10:45 PM - edited 07-23-2019 10:47 PM
If you try your sim in another unlocked phone or one that you know works with Telus/Koodo/pm your sim will probably work without any problems.
I did this more than once and with the phones that nobody knew who original carrier was, some bought from stores like Cisco or Walmart so it could be anybody really. Original manufacturer was always success.
Here is a similar discussion
https://forums.fido.ca/t5/Phones-and-Devices/Samsung-SIM-Network-Unlock-Help/td-p/134969
07-23-2019 07:23 PM - edited 07-23-2019 07:31 PM
@Alireja wrote:@cavemantoronto WHAT IS PUK CODE?
The phone isn't asking for that type of puk. From picture, it says sim network puk. That isn't for the sim card but for phone lock to another carrier. Your link is for a different type of PUK.
07-23-2019 06:33 PM
07-23-2019 06:07 PM - edited 07-23-2019 06:14 PM
@Alireja wrote:@Ocampo0225 It's nothing to do with the phone. It's SIM thing. When you enter wrong PIN code, it'll ask for PUK code.
That means your SIM is locked. You defenitely need to contact someone from moderator team.
Sorry, no. Network unlock puk is a phone thing. Moderators can't help.
07-23-2019 06:02 PM
07-23-2019 05:57 PM
@Ocampo0225 wrote:Hello! Where can I get a PUK code?
Phone locked to other carrier. Public Mobile can't help so don't contact moderators. Someone has tried to unlock phone too many times and now you need master unlock code before network unlock pin code will work.
07-23-2019 05:56 PM - edited 07-23-2019 05:58 PM
Previous provider or phone manufacturer
Manufacturer is your best bet
Go to their Canadian site (if you got the phone in Canada) and contact them by chat takes less than 5 minutes.
I never had luck with previous provider if phone is older
