When the moderator closes a ticket
CellphoneuserPM
I had a ticket which was closed after 24 hours of no response. I responded a little after 24 hours and would like to know if the moderator will respond or do I have to open another ticket?
7 REPLIES 7
popping
@Luddite wrote:
@popping Just fyi: last time I looked "Enable email for incoming private message" is ON by default.
Thank you for pointing that out as I am on the community every day and I disable the email option.  I updated my post to include a condition if email for incoming private message option is not enabled.  It will be in my future posts too.
BearFBI
@CellphoneuserPM I'm not sure. I was contacting a mod regarding an issue with *611 and I wanted to ask if they resolved it yet. The Private Message i replied to was 4 weeks old and I still haven't got a response to this day. That was about 2 months ago. Its either they didn't want to awnser that or the message got lost.
Its best to create another ticket.
popping
@CellphoneuserPM
Just reply from the closed private message with the old ticket number as the subject.  I think you will get a fast resolution if you stay with the same ticket # than create a new ticket.  Just my 2 cents.
You can enable email notification after receiving a private message at your INBOX if it is not enabled.
My settings --> PREFERENCES --> Private Messenger --> enable "Receive email notifications for new private messages' --> Save.  This will make sure that you will not miss any more response and don't have to login the the community forum to check on your INBOX frequently..
Staliger
@CellphoneuserPM The system may close tickets automatically it seems. Just create a new one or send a direct message to mods.
gblackma
@CellphoneuserPM there is a chance that they may respond. However tickets are usually declared closed for lack of response after 24 hours. So, I would contact them again on the subject. Stay safe.
gpixel
@CellphoneuserPM they will still respond, but I would just create another ticket through SIMon to get a faster response. if it's not that important, I would just wait
