When calling a certain #, the phone will just hang up
08-07-2023
08:26 AM
08-07-2023
12:20 PM
computergeek541
I've only noticed this with Public Mobile provider: when I call my work, after 7 rings, the voice-mail is programmed to kick in and you can leave a message. However, when trying with a Samsung and Apple phone who's provider is PM (Public Mobile), it always hangs up before getting to the voice-mail and I'm not able to leave a message. However, when someone else calls that had a different provider, they get the voice-mail and are able to leave a message. Does anyone know why this happens?
Service
08-23-2023 03:41 PM
I did try without the 1, and same thing. Hangs up.
08-23-2023 03:40 PM
Oh, and I do have a 1 in front of the #.
08-23-2023 03:30 PM
is that a Canadian phone number?
If you check your Usage log on My Account, does that phone number show up?
https://myaccount.publicmobile.ca/en/account/plan/usage-details
Any of your friend using Telus or Koodo? can you ask them to check for you as well?
And I think it is best to open ticket with support and have them to investigate further:
08-23-2023 03:17 PM
Just to clarify: this is when I call the company i work at, from my cell, it will automatically hang up before I get to the voice-mail. When other coworkers call, the company voice-mail comes up. It doesn't for me, it hangs up before it gets to the voice-mail each time. We've even reduced the # of rings and it always hangs up before the voice-mail kicks in.
I had someone else with Public Mobile try, N the same thing happens. When other people call that don't have Public Mobile, they get the voice-mail
08-07-2023 10:12 AM
What happens if you set up to answer after 5 or 4 rings?
08-07-2023 08:30 AM
so, someone else call that same number can leave a message?
did it just happen today or yesterday? or this is a problem for long time?
first , try reboot your phone
if you have been calling using 10 digits, try to call with a 1 in front of it.
On the other hand, if you are already calling with a 1 in front of the 10 digits, try only call using 10 digits without the 1
