What should I do if I forgot my login ID and password?
02-27-2020 11:38 PM - edited 01-05-2022 09:41 AM
02-28-2020 07:49 AM
@yanghao941le your login id is your email address.
If you have multiple, try the lost password with each email address you have. If you get an error that address is not valid. If you go to the next step you found your email address you can then continue the forgot password process.
02-27-2020 11:59 PM
@yanghao941le wrote:What should I do if I forgot my login ID and password?
@yanghao941le Contact moderators: click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-27-2020 11:46 PM
@yanghao941le , you might be able to find the login ID (email address) by trying to locate the welcome email from Public Mobile when you first activated. With that information you can do a password reset. If you are unable to get the email address, then you need to contact the moderator team for support. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
