07-22-2025
04:55 PM
07-22-2025
05:47 PM
computergeek541
I try to log into my account it keeps saying email and password don't match.I even changed my password and it still says they don't match. So I am doing this from my wife's phone
07-22-2025 05:40 PM
Did you try login to your account on PM app your wife’s phone?
Remember to logout of her account before you try login to your account.
07-22-2025 04:57 PM
Maybe you used the wrong login email. PM can help.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
07-22-2025 04:57 PM
hi @rustle
you will need PM support agent to help. You can submit ticket by direct message:
