What's going on
andronalds
Why can't I use my phone or sign in
21 REPLIES 21
RossN
@andronalds hi dial *611 to see if your account is active
andronalds
I tried and it tells me not registered or something my phone was working fine earlier
Maybe have a look at devicecheck.ca
Can you login to your account using another device?
@andronalds check in your self serve account and check last four digits of your sim you may have been sim jacked
andronalds
How do I do that
Hi @andronalds is your voice service working but when using data, it asks you to sign in? if that is the case, you ran out of data
andronalds
Timer
@andronalds
Check the status of service outages
@andronalds you sign in to your self serve account go to profile you will see your sim number there , check it with your sim number in your phone
