07-24-2025
09:47 AM
07-24-2025
02:20 PM
computergeek541
Does anyone know the difference between the two SIM cards listed on PM’s Amazon page? Ones $4.99 and one is $9.99 . Everything I keep seeing says 0 difference so just wanted to make sure
07-24-2025 10:27 AM
@JessA13 , I think the cheaper listing is old stock. There was a branding change along the way and the SIM cards took on a different color scheme. Otherwise they all work the same. I am still using the same SIM card since 2016.
07-24-2025 10:19 AM
for sometime, the new style cards are $10 and the old design is $5. But the difference is just the look, the sim itself is the same. Some agent told us they give a discount for old design as they want to get rid of those first.
Also, when you buy, make sure you choose Sold by Public Mobile and ship by Amazon., or this link is good:
07-24-2025 09:58 AM
Hi
thank you 😂 I was confused why they have 2 SIM cards on their Amazon page 😂
07-24-2025 09:58 AM
hi @JessA13
Same, no difference. Order it from Amazon. I do it all the time
07-24-2025 09:54 AM
Could be old and new offer.
SIM is a SIM; you should get a physical SIM with all adapters (3-in-1) as long as it is a real SIM and not scam or fake or previously activated thus useless I would go for a cheaper one.
