HI@SVN Yes, it was 3x Public points reward. Usually Public point is 5% , with 3x rewrds, you have 10% extra for one year
So, what they do is to give you 15% back all all spending you have on Public mobile. So, if your plan is $25, you will get 3.75 points on your My Rewards, it is equivalent to $3.75
So, you can login to My Rewards https://www.publicmobile.ca/myrewards to check your current points. Once you have enough for 15 points, you can redeem for $15 bill credit
