What is going on !!
Michwhea
I'm trying to make an important call.
Says I cant !!!!!!!
14 REPLIES 14
CS_Agent
Customer Support Agent
Hi there@Michwhea
For any inquiries please reach our Moderators by completing a ticket at the link below:
https://bit.ly/2HK8Bnb
Stay safe!
Public Mobile Team
maggamoka
If it's because you're on the $15 plan, and you've used your 100 minutes, you could text the person, and tell the person to call you. *Incoming* minute are unlimited. Just an idea, I don't know if it's feasible in your situation.
kelvarnsen
Can you share the number? If it has too many digits PM kind of freaks out a bit and won't connect. Like those 1-800 numbers where the rest of the digits are letters and there are more than 7.
@Michwhea
We can understand your frustration but a little less colourful language and a little more feedback and we can work on fixing your issue. Try rebooting your phone. Try a couple of different numbers. Put a (1) in front of the number you are calling....dial it manually not from contacts. What happens when you call 611?
mpcdesign
@Michwhea, so are you able to use your phone now?
It says you registered with Public Mobile since February 2020, you kinda know the drill it's a pre-paid plan. If you have a limited amount of calls (100 minutes for the $15 plan) vs unlimited (plans that are $25 plus), it could be you are out minutes.
If so, just buy an add-on for $5 for 500 minutes. Just make sure you have sufficient funds in your account to apply this asap.
If by chance you have unlimited minutes, then that's a bigger issue on hand then. The others have already told you how to contact SIMon, which is the fastest way to contact the moderators.
yanzhiqiang
Contact moderator by clicking the ?mark at bottom right,wish your problem solved quickly.
Staliger
@Michwhea Check your self-service account please. Are you on 15$ plan? If yes, you ran our of your 10 mins for a mons, so you need to buy a 500min addon.
@Michwhea wrote:
How do I get someone to fix this!!!
What am I paying for ???
You are paying for a hands-on, self-serve kinda provider.
Try adding a 1 in front of the 10 digits.
If you're on the $15 plan maybe you've run out of minutes.
Maybe you're trying to call a US number.
Maybe you're mis-dialing.
Michwhea
edited by computergeek541: Community terms of service regardling language
james1234
Good day!
I understand your frustration here is what you can do for sure:
1. Restart your mobile device and verify if it`s able to reconnect to Public Mobile. Write down any error messages.
2. If no, verify your SIM card is properly inserted and try again.
3. Log online into the self-serve area at https://selfserve.publicmobile.ca/ and verify your account is still active.
4. Dial *611 from your device and see if your device is still provisioned.
Kindly,
James David
@Michwhea wrote:
Says I dont have talk on my plan
If you're on a $10 or $15 plan, this could mean that you are out of outgoing minutes.  I would log into your account at selfserve.publicmobile.ca to see if that's the case, at least if you're oin one of those lower-priced plans that don't include unlimited calling.
This message is also sometimes heard if a mistake is made in dialing the number.
Michwhea
@Michwhea
Is there an error message played back when you try to make a call?
Michwhea
Are there moderators or something here ???
Severely pissed
