08-04-2018 08:42 AM - edited 01-04-2022 06:39 PM
08-04-2018 10:45 AM
As the previous person mentioned, suspended accounts need mod intervention. If you have already paid for your renewal (Autopay or otherwise) if you were to change the plan yourself you would lose the money you paid towards it and instantly start on the new plan unless you schedule it for your next renewal date. The mods need to adjust your account for you to prevent the loss of funds for a between renewal dates switch.
To change a plan you have to log into your "My Account" (Self Service) and the line directly under Account Status tells you your current plan. There is a button on the right side of that box that lets you change your plan. (Again assuming your account is active).
08-04-2018 09:22 AM
@tash-had, if your account is in suspended state, you can't make plan changes. You will need to reach out to the moderator team to complete the plan change. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
