Waived SIM card fee rejected at Telus store
ltdbc
I'm contemplating moving from Koodo to Public Mobile, to the $29 40 GB plan currently offered. The website indicates the $10 SIM card fee is waived if collected from a Telus or Koodo store but when I checked with a Telus store at Hillside Mall, Victoria, I was told they  "are required to charge for the Public Mobile  SIM card" Which is correct?
2 REPLIES 2
HI @ltdbc
the $10 discount only applies for sim card delivery by mail.  And yes, sim delivery could be long, like 3 days to 3 weeks.
HALIMACS
@ltdbc
If they charge you for it at the store, simply ask the customer support agents after activation and they will undoubtedly waive the fee by applying a credit to your account.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
